Dude, you had two s1's right in your neck of the woods last night - we had a dyno day at Unigroup and went to Fully Tabouli at Pemulwuy shops last night afterwards...
think its time i came out of the shadows and said hello to some members
i parked my car at pemulway last night and some kids are going
" brooooo that station wagon is turbo " "what the f**k is it"
im glad they didnt realise i got out of the car
Today I spotted three dark green Stags.
First was in Ashmore Rd
Second parked in construction site near Aussie Fair
Third was in my garage.lol
We are not the only ones Nick!
spotted an m35 broke road in pokolbin (hunter valley vineyards) with the plates ST***A looked sweet, i have seen this before i think at one fo the meets/shows
and got a wave from white s1 in lochinvar on the way home, 2 in the same day lol
That would have been Iain (ziel20l), must be a dirty weekend away with the missus!!
Busted! :nyaanyaa:
Probably even worse if he didn't take his missus, could be some gossip on this one.
Nice spotting :nyaanyaa:
spotted a silver m35 in the riverstone/schofields memorial club car park last night.....possibly the one i always see on annangrove road?
also today spotted a gold arx parked on a road near canterbury road today, around 6 maybe...
now all i need is a bronze and i have the whole set yeh? :nyaanyaa::nyaanyaa:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
