Saw a green S1/S2 stagea in the car park at Gravox factory in Seven Hills on Tuesday. I was going to the city by train and woke up when passing the complex. A pleasant surprise :) Are they a forum member by chance???
Possibly Nick (Goldzilla), he has a green machine and lives very close to the Seven Hills area.
I'm sure he will pipe up and let you know if it was him.
Saw a green S1/S2 stagea in the car park at Gravox factory in Seven Hills on Tuesday. I was going to the city by train and woke up when passing the complex. A pleasant surprise :yes: Are they a forum member by chance???
Hmm, I live VERY close by to that, but I don't remember what I did on Tuesday - what time was this?
Good day for spotting today, drove from Blacktown to Gosford and spotted 2 AR-X's about 30 minutes apart.
Both were even the same colour! (champagne I think it's called).
Spotted the first on Pennant Hills Road, he was turning off onto a side street, exchanged flashes of lights and a quick hoot.
Next was on the F3, near Berowra King M35 passed me in the fast lane and we exhanged hoots.
So there you go, a good day for spotting!
Blue M35 Nismo kitted, on the westgate freeway. had SA plates, awesome looking ride, you might of noticed my GF taking photo's. i was in the blue pulsar SSS.
also saw you parked at the Little River BP
this was Saturday around miday i think
Sounds like it couldve been me, I drove a section of the westgate freeway on saturday on my way back from the snow fields (Stayed in Melbourne friday night, then did the great ocean rd etc)
i did the GOR also :D to bad it was wet, much better on monday going home ?
i did the GOR also :/ to bad it was wet, much better on monday going home ?
Ah nice. We stayed on Lorne on Saturday, and then drove the scenic section of the GOR Sunday - was a stunning day for it, albeit windy. Monday was a nice day for driving also, an excellent trip over all :D
Spotted Phoenix88's yellow R34'd C34 at Pitlane Automotive.
Didn't have time to look under the bonnet, have you got the pod boxed/shielded yet?
Nah havent got that done yet. Im having electrical issues just trying to get them cleared up.
Seem to spot a black c34 on seaford rd at 7.30 most mornings any one on here?
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
