nah wasnt me but i have seen another white s2 heading that way in the past....maybe its a phantom :)
haha maybe thats twice ive seen it and thought it was you, and its always been at night too lol.
Forgot you lowered yours, that one looks like standard height
saw blue S2 stagea BP Morphett Vale at 3.30pm yesterday
little lad thought it looked neat
that would.ve been mine on the way to work. i'm amazed you could even tell that the car was blue, it's freakin filthy at the moment.
Spotted a bayside blue s2 c34 on Gipp st in the Valley on Friday night. Said g'day as I drove past, looked pretty stock. I thought that the only other one in queensland belinged to greenghost (myles). I guess not everyone who ownes one is on SAU aye
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
