spotted a silver c34 on dandy and warrigal road today exchanged waves...spoke to the owner of the blue stag in richmond once his wife drives it and was looking to sell it she did not want manual anymore
that was me in chaddy, have seen you a couple of times on dandy road, we must finnish work around the same time
may not be me you see only went that way due to freeway blocked off normally on dandy road for 200 meters to get on to blackburn road
spotted a grey m35 stag yesterday around 12:40 - 1:00pm at the corner of Canterbury & Mitcham rd, waiting to turn.
nearly went through on the red arrow and backed up a bit :down: lol.
gave you a toot as i was turning right.
spotted last night around 9.00pm: silver S2 (maybe had rims?) heading West on Mona Vale Rd near Frenchs Forest. Was in my other car, and he/she was moving at speed, so no chance to acknowledge ...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
