spotted a silver RS4 pulled over by cops at Christies beach this morning around 9.30ish, hope you didnt get done. then spotted another silver RS4 on Lonsdale highway, gave me a wave and did wave back dunno if they saw or not. anyone off of here ?? I was in the mrs white S2 RS4
Saw a white RS4 (Scotty), black ARX (Aaron), and burgundy ARX (KV2) on Saturday morning...
Can't wait till I pick up the are tomorrow nite...new exhaust...yuuuuummmmmmmm
My place is beginning to look like an import yard. :)
Exhaust is nearly finished mate, looks good too, just need the flange. How long before we find out what it flows? :whistling:
Hmm I know I haven't got it high flowed, but once I get the intercooler on, I think I'll take it to Cihan and have Emanage installed and tuned. if I got 200awkw I'll be happy...for a while :P
realllllllllly tempted to go ethanol though..............>_<
the turbos gonna say bye bye soon. might as well just do it. oh n if your looking for a front bar, theres an impul one on IM for $230 + shipping.
have a look.
Oh and the exhaust looks really good. i think i want one...:ninja:
Edited by AaronNM35
have a look.
I think Scotty said he wanted to see what a stock turbo will do on E85...maybe I should show him :P
Hmm that impul bar does look nice...but its gonna cost $500 just to get here, then another 2-300 to paint and fit. Whereas I can get an aero selection bar in a few weeks time for $400 already painted and ready to fit.
It does look cool though...:laugh:
oh in that case, look for the fog lights.. if you pick up your car and it doesnt have an exhaust.. Im just testing it for you..:happy:
LOL...r u running a custom as well? Thought u don't like quiet exhaust :P
Hmm stuff the foglights. The car's already got built in ones...no need for another. I know they look nicer but its not worth another $700...
Spotted a white S2 with Epic Body Kit of some description on King Street this morning. Had SA plates.
Hey man,
Do you work in Melbourne CBD? i think ive seen your car driving around towards the evening.
Spotted A white RS FOUR this morning on Hampton Street Hampton...
Bloke and a girl got into as they were leaving the Guitar shop I think?? Had nice white wheels too... top looking car if your on here!!
I was in the ute...
Saw a white S2 on Kings Road about 2:15 gave him the flash
Dont seem to be many 34s round my area but ive seen a Silver 35 a few times on the same road that doesnt seem to want to acknowledge im there :sleep:
Hey man,
Possibly, I do live and work in the CBD. I walk to work however so the car only comes out after hours.
If you see me out and about be sure to jump on the Horn.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
