that WAS me lol
did you enjoy the detour during the week because of the hole in the road?
if that was u did u change your plates the roads in ryde are all stuffed i wanted harder suspenshion but the roads are too bad for it
Edited by datzla
wow i thought i saw a diferent rego last time i am blind i think. My new plates come in 3 weeks i wanted AAAC34 but at 440.00 no thanks so i got
AAA34T 90.00 thats better
Lol, my plate is AAE34C! Had it for as long as I've had a car.
it is my work car so its AAA witch is adams auto accessories but i had to put 34t for fun my accountant said to put more work plates on it to make it look like more of a work car for tax reasons i said ok no problems then he even claimed my nistune hey its kind of a work expence so is the intercooler and turbo
Good to have a smart accountant.:thumbsup: Cruises could be a deductible as well; business promotion?
Spotted a silver M35 yesterday afternoon on Parramatta Rd somewhere between Stanmore and Burwood (can't remember exactly). I think it was an AR-X, it had the beard but it was all painted body-coloured. It didn't have an AXIS grill on the front or AXIS wheels.
