Spotted white C34 (plates DA XXXX) on Queens Rd Five Dock near the leisure centre around 5:30pm last evening.
Big tail pipe in which you can put yr hand up to service the motor :rofl2:
Tooted as I went past at the traffic lights when I turned left into Harris Rd.
That's exactly how i service it!
Saw you behind me too thought u were a maxima at first :P
Spotted Green C34 S1 Stanmore Rd Stanmore, was in the Fiat so no point in waving. Needs to have the rust under the door mirrors dealt with whistling.gif
Rust under the mirrors?
Well, that rules me out...
spotted nick heading into the city this afternoon while i was vacating the city
LOL, were you in a daze or something? I swear you looked at or around my car at least 3 times before you noticed me waving at you...
Today, spotted two M35s while heading out towards Windsor. One was silver and turned off Old Windsor Road where the Outback Steakhouse is in Parklea, the other was dark grey (rego: TW-xxx) and continued on Old Windsor, then Windsor Rd and turned off close to Windsor itself.
Spotted Jules in St Ives in his Silver M35 Axis around 6.30pm.. Good o see you Jules.
That be me, seen you a few times out and about. . anyone would think all we do is cruise the streets of Sydney. .
Perhaps one day you should swing past my house and drink a beverage. . cold frothy. .
Spotted the nice stags at all japan day but didn't see any owners. Sad that no one spotted my stag in the car park. But all good. Next year my stag will be there too together with my brothers 200SX
Glad you guys had your stags there today.
i was hiding under the trees for shade LOL but i also left early around 1ish
Spotted Pearl White C34 with Green P's on the M4 this afternoon; and was actually driving the Stag for once! :banana:
The pearl looks great in the sun mate.:thumbsup:
Waved, got a response; Is the owner on here?
hahah funny you should mention that, i was tired as hell and looked at your car and thought for ages "wow i know that car from somewhere, with those rims too" and THEN i realised it was you.
Nice one!
I am loving black wheels on a silver car lately.
Spotted a black M35 in Edinburgh this afternoon. Chrome wheels, I think Kenstyle front bar, maybe even whole kit. Rear bar didn't look stock. Looked pretty mint from afar. Pretty sure it was a female driver.
Edited by jasevr4
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
