Spotted white C34 (plates DA XXXX) on Queens Rd Five Dock near the leisure centre around 5:30pm last evening.
Big tail pipe in which you can put yr hand up to service the motor :rofl2:
Tooted as I went past at the traffic lights when I turned left into Harris Rd.
That's exactly how i service it!
Saw you behind me too thought u were a maxima at first :P
Spotted Green C34 S1 Stanmore Rd Stanmore, was in the Fiat so no point in waving. Needs to have the rust under the door mirrors dealt with whistling.gif
Rust under the mirrors?
Well, that rules me out...
spotted nick heading into the city this afternoon while i was vacating the city
LOL, were you in a daze or something? I swear you looked at or around my car at least 3 times before you noticed me waving at you...
Today, spotted two M35s while heading out towards Windsor. One was silver and turned off Old Windsor Road where the Outback Steakhouse is in Parklea, the other was dark grey (rego: TW-xxx) and continued on Old Windsor, then Windsor Rd and turned off close to Windsor itself.
Spotted Jules in St Ives in his Silver M35 Axis around 6.30pm.. Good o see you Jules.
That be me, seen you a few times out and about. . anyone would think all we do is cruise the streets of Sydney. .
Perhaps one day you should swing past my house and drink a beverage. . cold frothy. .
Spotted the nice stags at all japan day but didn't see any owners. Sad that no one spotted my stag in the car park. But all good. Next year my stag will be there too together with my brothers 200SX
Glad you guys had your stags there today.
i was hiding under the trees for shade LOL but i also left early around 1ish
Spotted Pearl White C34 with Green P's on the M4 this afternoon; and was actually driving the Stag for once! :banana:
The pearl looks great in the sun mate.:thumbsup:
Waved, got a response; Is the owner on here?
hahah funny you should mention that, i was tired as hell and looked at your car and thought for ages "wow i know that car from somewhere, with those rims too" and THEN i realised it was you.
Nice one!
I am loving black wheels on a silver car lately.
Spotted a black M35 in Edinburgh this afternoon. Chrome wheels, I think Kenstyle front bar, maybe even whole kit. Rear bar didn't look stock. Looked pretty mint from afar. Pretty sure it was a female driver.
Edited by jasevr4
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
