Spotted some of the usual suspects at the jaf cruise last night me and dream 15 "iculkn" are starting to wonder if we are lepers or if its just jealousy that leads to being ignored by some bit sad really
spotted a blue M35 RS/RX around the Northbridge area parked out side a house yesterdat around 2:30pm
and then spotted a burgandy M35 ARX (with a checky money sticker in the back window and nismo sticker on the bumper) driving down Concord Rd, Rhodes. I was behind you dont know if you saw me but i turned down Homebushbay Dr. that was around 5pm'ish
Silver s1 rs4 at olympic dam, roxby downs.
A little unusual around this neck of the woods
Pffttt... ya not wrong. That'd be Landcruiser territory wouldnt it???
http://maps.google.com.au/maps?q=olympic+dam+&hl=en&ll=-31.278551,140.19104&spn=4.013594,8.453979&sll=-30.911651,139.356079&sspn=4.029111,10.546875&vpsrc=6&hnear=Olympic+Dam+South+Australia&t=h&z=8
Haha nearly is, there is normal roads out here :-)
I have seen a legnum, r32 gtst, r34 gtr and heard about a r35 gtr out here before.
Spotted a Silver S1 Stag Cruise past me the other night at 7.05pm at cnr of Highbury & Blackburn Rd Mt Waverly/E.Burwood where H.Jacks is. Was on Blacky Rd heading in Blacky direction.
Has STAGEA down the side on the doors, plates were MRNISIN (i think, i was hidden next to a mini bus, last second spot).
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
