Yesterday at around 6 pm on Narre Warren Nth Rd. and today at noon on south Gippsland hwy. Black M35 with personalized plates on first view was in my inlaw's car and in the second getting into my car...so no chance to make contact...
Spotted a white M35 on painted 350z rims a the meet up for the SAU NSW Wisemans Ferry Cruise.
Sorry, didn't get a chance to meet up, I bailed before the gorge- Cars not tuned yet...
Saw the same one driving past the pub at Wisemans, when we pulled up on the bike today.
had a laugh when someones mum (in back streets near kesters and bridge rd) told me not to park in her driveway cos she wanted to, (her son has white dayz fronted rs4s with white wheels and ms dolphin grille, me driving white stock fronted rs4 with black d1's and ms dolphin grille) wound down the window to say hi and we both had a chuckle. good on you mum.
did u give her a flash ? ;)
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
