Spotted a white M35 (might have been a PM35) heading west on Queens Road in Five Dock while I was heading east. Spotted it right near where the industrial area ends and the houses start again.
Spotted a white m35 on stopped at traffic lights at Wilson Way run off on Great Western Highway at Blaxland going west around 16:25 yesterday.
Aero front bar, std rear.
Older woman driver exchanged waves.
This one seem to get around a bit; I saw it go past my work the other day.
