I've spotted that one there as well Leigh. I gather he's working at the site. I don't know enough about C34's to pick up what it was exactly, but looked nice.
Thanks. theres ALOT of stags driving over sextons hill, i usually see at least 1 a day
i think he's one of those guys who likes the s1 front over the s2 :rolleyes: and stuck s1 lights in cause the back end was s2 dayz
for the record, yes i am one of those guys that likes the ser 1 front, i bought the car damaged and it needed a front anyway. before u say it R34 front was WAY out of the budget. but my main motivation for the front swap was that i have 2 RS4S stags and i wanted to set them apart a bit.
(Adelaide) White C34 which looked so much like mine looked really nice and recieved a wave on chandlers hill road a bout number plates where slo***
that was the wife taking kids to school, thought you would run into her sooner or later as i have seen all the other ones you have seen
? Yeh just lately I've seen so many stags around this area!Your car looks real nice!!i thought I recieved an extra nice wave that's coz it was a lady too ?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
