On Tuesday 10 July around 4:30pm I passed a red C34 S2 on Albatross Road, Nowra Hill NSW. I'm sure you would remember passing me, I was in a white Toyota Camry (rental) - a car as memorable as it is thrilling to drive :rolleyes: .
Then about a k up the road I saw a silver C34 S2 parked on the side of the road, which I also re-spotted the next morning in the same spot. Probably this one (with the twin sunroofs).
Yesterday morning (Friday) about 8:30 I seen a black C34 S2 on Yass Rd Queanbeyan NSW (parked) with SA plates. This time I was in my white R31 wagon, much more enjoyable to drive :D .
Edited by QJQ
And put in a very good account for yourselves too, by your times. Seriously, you two were pretty much the quickest all day through out the different courses. Very impressed.
I'll have a chance, but today just wasnt it. Catch you out there soon. Sorry. Didn't get a chance to say bye, Theo, but thanks for the ride!
Spotted this S2 Autech on Ebayed lastnite, very seriously thought about going to look at it & buying it last year when I was looking. It was on carsales for $24K. Glad I didn't!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.ebay.com.au/itm/320943252107?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Grey M35 RS on FTG Road Scoresby tonight. Stopped at the lights and said hi.
Took me a few seconds to realise there was another stag along side me.
Sorry, I thought it was a Volvo just from the colour. :no:
Will you be at the Stagea cruise this Sunday?
Spotted Theo, Alex, Ryan, Shaun and Gavin on Sunday @ Texi.
Theo and Ryan, was awesome to see you guys out there cutting it up. Alex and Ryan, major thanks for helping out on the day - these events don't run without volunteers like yourself. Gavin, was good to meet you, too.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
