Caught a glimpse of a silver M35 just before 6pm heading up Sutton Rd just outside Queanbeyan NSW. Had what appeared to be snowboards on the roof - probably returning from an awesome time at the snow.
Silver axis blackened lights behind me at EC
hello :action-smiley-069:
yeah i seen 5 stagea's your gold M35 a white C34 and a white C34 with R34 gtr rims, a yellow S1 C34 with queensland plates and as i was leaving another M35 on Brabham Dr.
The blackened lights and black grill looks great
saw the yellow rs4s aswell, passed on reservior rd, i gave a wave and revieved one back, i was in my silver c34 s2.
cheers.
spotted ur car in the paddock on saturday.
there were a few more, i think a M35 with ACT plates.........
[NSW] Spotted yesterday a sliver C34 turning left off Lane Cove Road onto Waterloo Road Macquarie Park around 2:20pm and then a white C34 (260?) in Blacktown near the library around 5:20pm.
Someone has finaly spotted my car, that would have been my missus taking my 3yr old to see the animals at the park!
Yeah I saw it there after I came out. Went up to take a photo, discovered a person in the passenger seat, she freaked a little... It was awkward.
That would have been me most likely. Looking around. Nd as u could guess not from area. From Adelaide. But I did see a s2 in my travels around there as well. Silver may have been u. Think it was near Bose or something.
Couldn't see your plates you were side on, noticed your sticker bomber side window :) welcome to Sydney mate- the road next to the stadium looks good at night if you still in the area.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
