Spotted a C34 at KFC in Allambie (Skyline Shops to be exact) with the number plates OVLOV. On here? I had a good laugh.
I see that car a lot. Have put it up in this spotted thread a few times and no response. I think it's a female owner.
Spotted a silver S2 parked near Pendle Hill station.
Also spotted a white RS4S DAYZ manual at Challenger spares too, plenty of parts to scab off it!
Spotted that silver s2 a few times in that spot.
And please don't take the rear spoiler from the white RS4S - I plan to go in there after New Year's to get that and some other parts off it too. That's just around the corner from my house, too.
Spotted a silver Axis yesterday morning at Seven Hills Rd & Abbott Rd (was that you Dave?), & what a day in the 'Riff, at 3:50pm, spotted a white S2 C34 on the Northern rd flyover of the M4. Then after I turned right on the M4, spotted another white S2 C34 with a dayz kit on the slip rd off the M4 for the Northern Rd, & on my back up the M4 at 4:40pm spotted ANOTHER white S2 C34 heading west between the Northern & Kingswood Rd bridges!
Oh don't worry, I don't have any interest in the spoiler. I went there to get a replacement mirror for mine ... they've got a silver S1 RS4 there too which my mates and I have salvaged a few parts off :lol:
Yeh mate would have been on the way to work, didn't notice your car? I spotted a silver m35 last Monday or Tuesday morning headed down Abbott Rd few cars ahead of me.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
