1. Square bumper with trapezoid exhaust cut out and stock peashooter pipes
2. Slimline plates with lower brackets chillin on their own.
3. 4x4 ride height
4. No rear wing
5. No badges
6. No roof racks
Spotted Gavin in his yellow C34 and Alex in his PNM35 tonight at the SAU-NSW tech night @ JEM.
What too lazy to stick your head out on the street and see mine as well :P
Was your car there or did you bring something else?
My bad.that was me bro..my mrs saw u didnt tel me..im usually scaning the streets for stags evryehr i go.couldnt beleive i misd u.lol.definatli heard u go past tho!
And would never ignore a fellow stagea owner!
Ever
I was just stirring the pot LOL, no hard feelings :)
