Could possible be this one
http://www.carsales.com.au/private/details/Nissan-Stagea-2003/SSE-AD-415562/?Cr=12&sdmvc=1
Its been for sale for 5 months that I know of.
That car needs more low, and blacker trim. And black wheels before it'd look good, IMO.
Spotted Gav in his yellow C34 s2 on Old Windsor Road in Seven Hills this afternoon, then Dave (I think???) at the very last moment in his NM35 AXIS about 10mins later as I was waiting to tun into my street.
Hey Nick, yeah that was me, your car was looking schmick as!
I've spotted Gav a couple times goin down Abbott rd in the arvo, while I'm standing out the front of work and I usually hear you coming before I see the car :)
Spotted a Stagea mini meet in the Macca's carpark at Croydon this afternoon.
Well actually it was just 2 Stagea's. But pretty rare to see more than one in the same location! :P
Can tell you , there are two in my driveway...Mine and the son's.... another less than 250 meters... and the forth just two streets away. Here in Springwood they are as widespread as GMH Commandoors
Not sure if you meant us, but that was me in my dark green S1, Brendan in his pearl white s2, and eventually Laurence in his black s1 meeting up for a quick chat and exchange of parts at the BP/McDonalds on Parramatta Rd in Five Dock on Friday arvo.
I also spotted a silver s1 driving through behind the servo on R33/S14 wheels, and only just now(!) made the connection that it could have been Shaun.
Adelaide.. about 1.30 this arvo on eyre st. Seaview downs. Silver s2 heading up the hill. I was driving down :) dont know if iys just cos im driving a stag now bit ive been seeing heaps of them lately lol
Edited by staglover
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
