Tryed a search but didn't have much luck, can anyone point me to a site or tell me the difference between the NUR Spec R34 GTR and the standard models.. Also I am right in saying the only difference between Mspec & Stock Vspecs is the softer suspension and leather interior...
That is correct there are on 50 M-Spec made in 2001 and 1000 Nur (75% M-Spec and 25% V-Spec II) made in 2002.
Off the top of my head yes basically same as the V-Spec II but different suspension internal damper setup though same spring rate and slightly smaller stabilizers...springs and shock absorbers are also gold in colour. Champagne gold colour which also follows through into the interior stitching...also the steering wheel dia is 3mm larger not that you will notice that :cheers:.
PM Rezz (Justin) I lend him a couple of my Skyline books and I'm sure the M-Specs are covered in them.
mesh, i'll give you the catalogues for both the regular and the Nur GTR's and you can see the differences for yourself... :cheers:
Thanks Shan, I'm gunna hold you to that :D
We're sort of thinking about looking for a NUR 34.. and I guess just wanted to clarify whether 1 particular NUR model, had more "exclusivity/rare" appeal than aother.. What I did find is that the VspecII Nur had the carbon bonnet and harder suspension, where the Mspec had the softer tuned suspension and NO carbon bonnet..
while looking out for cars for j-spec, I came across a White R34 GTR VSpec II Nur that next to no km on the clock since manufacture... Came with a factory CF bonnet and every extra imaginable. I can try and see if its still available if you want.
I'll bring the catalogues for both GTR's to the meeting on the 19th... you can check them out there.
meshmesh - i hope u find something. i couldnt find anything. The motor in my 33 is a 34N1 i dont know if that means is from a NUR SPEC or what ? i couldnt even find anything about the turbos mine aparantly has RR581's ? which is the larger of the N1's ?
any info on these NUR SPEC 34's would be tops
If I may...
Only BNR34 N1 and Nur use the same turbo spec:
Compressor: C106 (normal BNR34 is C100)
Turbine: GT-25 (same as BNR34)
Turbine wheel: steel (normal BNR34 as you know is ceramic)
A/R: 0.60/0.64 (normal BNR34 is 0.53/0.48)
Boost is same 0.93bars
Yeah but the M-Spec has leather :D
Im looking into trimming my interior black leather with red stitching. Anyone know any good leather trimmers in Sydney? I saw a photo of this in GTR magazine and it looks good.
If I was going for a late model 34 I would try for a M-Spec in champagne gold. Great car and a more practical daily driver.
Thanks for that link GTS_DUY .. I tried the Nissan jp site, but even with the translation I couldn't understand jack.
sewid, you reckon the Mspec ha and that limited colour which I think is called "millenium Jade", your the second person to say that. Isn't the Mspec for "no offence" soft coks.. ? with it's saloon type suspension? I mean I really love the leather, only wish the Vspec came with leather, as I believe it has the Carbon bonnet where the Mspec doesn't.. I guess though we'll be happy with either of them.
PS: We have a mate that owns a Nissan Dealership here in Vic, and plan on asking him whether Nissan AU would import one in for us? Anyone have any ideas on that?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
