  • Replies 138
awesome day guys!!
im sure u were up top at the same time i was jetdat cause some of those pics look like they were taken when i was up there with the video camera taking footage... maybe... :(
nice pics guys! i'll put up a little footage... in lowish quality so people on dialup can view em once ive converted it.
check out that black beast... i heard the guy that owns it is a jive ass pimp!! :)
inark, i was up there for a while so maybe we were there at the same time lol
as i was walking down the stairs i saw your car and went over to inspect it and snap some pics and show/tell the boys all about your beast...although we never met in person i have seen a pic or two of you on the forums so i kinda know what you look like but didnt see you anywhere near your car...
yeah i didnt hang around it much other than getting crap out of it and stuff.
is all good :(
:( Nah ni, my cars not that much of a beast, pritty stock actually. But i'll take the compliment anyway. Oh an i'm only a pimp coz your my bitch. Now, too much talkie talkie, go make me some cash biatch!
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
