Every State has this exept for you guyz so here ya go.
This is a thread which we jjust tork complete crap about anything, just for the fun of it...
Lol i just noticed your signiture Cassi lol. So where is this mafia based?
  • Like 1
https://www.sau.com.au/forums/topic/54460-the-wasteland-act-style/
I'm down with the...errr...South-by-South-East...ummm.What would anyone classify Jerra' as?!Skylinegal!SxyGTST!Help me out on this one!I guess I'm a Southsider...even if Queensland is still in my blood!
queenslands still well and truely in my blood jayce! i miss my home land!!!
im kinda south central i guess you'd call it? weston anyway
I'm hearin' ya 'bout the Sunshine State!I'm getting misty-eyed just thinking about it...
South-Central,you say?Kinda Ice-T,dontcha think?!Word up,G.
LTSJayce: Jerra is roundabout eastish...more like a compound really!!!
All I can say is GO THE BRONCOS.......COME ON COWBOYS!!!!!!......THE MIGHTY MIGHTY LIONS.......AND THE QLD REDS WILL BEAT THE BRUMBIES NEXT YEAR!!!!!! (well at least one game!) so what state do I come from????? hahahaha
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
