:( My Rant
On the way down the Monaro Hwy today I had two (2) things that pi55ed me orf.
1st. An accident - Vehicles well off the road - minimal damage. Slowed trafic down to 10-20km's all the way back up towards Fyshwick. !@#$%^&* ppl just needed to slow down and a have a gawk at a tow truck in the bush. Big Fizz - GET OVER IT.
2nd. A schmuck in a blue toy car who's lucky I didn't get his @#$%^ number plates. Dweebs with Big !@#$% Mouth's. GRRRRRRRR!
Anyone wanna give me a ride in a GTR for my B'day next week??? I own a GTS-t, but never been in a GTR......Please?!?!
Hey Tim - Happy Birfday mate:cheers:. Hope you get ShizzleFaced and enjoyed your day. :headspin:
Bloody hell, i copped a 75 in a 50 zone speeding fine just outside tarcutta tonight on my way home from melbourne. i didn't even see the 50 sign, it's on the edge of town and the street lights had ended. it looked like the edge of town and not a residential area.
The cop was sitting on the side of the road with all his lights off, then he turned his red and blues on, and i pulled over. the bloke said he got me doing 75 and that's when he turned the lights on. as soon as he had turned them on i instinctively looked at my speedo and i was doing 60, so i don't know what he was on.
i'm taking this one to court, it's a joke that that area is a 50, and the bloody cop is lying about the speed i was doing
Nike - Just do it. It might get a lower penalty. Long way to go back to court though.
They're spose to show you your speed if questionable.
Tarcutta are Mo Fo's anyway. Do you want to compare speeding tickets from that area. I used to do the Albury trip a fair bit (fortnightly) so almost use first names now with the cops all the way to Albury. Two maximum fines in one day, 6 points $1050 bucks.
It's bloody stupid. Common Law used to be if the area was not lit (built up area) by street lights it was no longer residential. Read 100km zone. Now they do the slow down zone b4 the town crap. 100-80-60-50 - stall.
If you follow the public safety thing you should be booked on the approach not the exit of a 1 whores town.
As i was coming through murrumbateman i looked at the speed zones, and when it turns into 50, there is a street light 50m past the sign, then on the other side of town, the 70 zone starts as soon as last street light is past, then it goes to 100 after a few sharp corners.
This post has gone dead, so I will liven it up a bit with my presence, and my really bad spelling, and some smilies.
:ufo: :ufo: :ufo: :ufo:
:ghost: :ghost: :ghost: :ghost: :ghost:
:headspin: :headspin: :headspin: :headspin:
:bananaman :bananaman :bananaman :bananaman
:sadam: :sadam:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
