well just got back from my holiday in newcastle/gf's grad. did some quad bike riding in the sand dunes of Stockton went to the beach and I now have a screwed knee :) like literally struggling to walk I think its from when I went bush 2 weeks ago and jumped off a log about 3 meters ;) anyways went to physio (dodgy spelling I know) and she reckons 3 - 4 weeks to be all good again so yea wont be doing anything adventurous for a while
well it was a combined effort, it was my idea, Jayce put in ALL the effort, and Jayce, Myself, Andrew (supafly) and Beau will go quarters in all costs. But its still from behalf of all the members here.
edit: p.s gus is gay
dont pick on the gay guy
you you metro freak. lol.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
