Well apparently it was sent in 2 packages they now tell me. however, both packages have the same EMS tracking number, which doesn't help me if one package has been lost, because on their records it states that it has been received. what a shitstorm
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
