Hey guys, Haven't checked this thread for a while so i thought i would stop in.
We finally got a house down there, but it is going to suck getting use to cold weather, bit differen't from the sunny coast.
The house is in Gungahlin, so hopefully we are not to far out from everywhere.
haha, i still dont know how he does that, people say its soapy ground but either way its impressive
Keeping this thread up there, a guy from my work had a massive crash last night. Basically he was driving home along the back road and a painters tarp was left on the road, he saw it at the last moment and panicked thinking it was a cow on the road so he swerved and over corrected, his tyre hit the dirt shoulder and threw him into a ditch, rolling his car and setting it on fire with him still in it, luckily his door was still able to be opened and he wasn't knocked out because from what i saw this morning it was an inferno. Everything not metal had been melted off and all that was left was a steel shell in a large burntout patch of grass. He was so shocked at the time that he didn't even know he had rolled and still denies it (despite caved in roof) and before getting out of the car he had tried reversing out of the ditch while it as on fire.
Crazy stuff
I didn't know cars actually set on fire when they rolled. I could imagine a car with carburettor might but this was a fairly recent Ford that would of ignited immediately after rolling (he left work at 7:30, 10 minutes to drive to where he crashed, called my boss at 7:45)
so I get pulled over in Mawson for doing 72 in a 60 zone tonight...
grumpy old man cop tells me off for doing 72 in a residential area, I tell him I'm sorry and just wasn't concentrating, he takes my licence and has a quick look over my car and then starts punching details into his little speeding fine machine.
He comes back to my window with licence and ticket.... and says "here you go, this is an official CAUTION" and gives me a printout that looks exactly like a ticket and even says "infringement notice" but it's not. wooohooO!!!!!
I think my car needs a wash BADLY... he wrote purple instead of red as the colour :banana:
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
