i know theres a video thread but this thread needs to stay up and this video is holy crap awesome! Even if you're not a fan of graffiti art, the amount of time and effort that would of gone into this is impressive on its own.
Edited by Baconer
son of rajab Mary duude!
I'm a massive fan of stencil's and Dolk's work, but format aide, this one of the most impressive works Ive ever seen, hugely creative, very effective little passage.
Feels like 70's LSD stop / go animation styles lol.
Nice find
nige off 104.7 bought a skyline, anyone else hear about it?
he's always loved them... I have him as my friend on facebook (no I'm not special, I did it as part of that promo where you could win a computer if you added him) and he has a pic of a GTR and how much he loves them etc...
yeah i added him for that as well, after the comp finished i added scotty as well
dam, my first 4 times on reaction game were .187 .185 .185 .186. 5th was .249
Anyway i was looking for a car to tow my track car with. Something with a lot of torque and AWD. Money not an issue
4:30 is an ungodly hour, have to get car ready for Classic Celica cruise to sydney. There are dedicated members of the cruise who have car trailers for cars that don't make it all the way :P
Done hard drunk after drinking since lunch, got this on my second attempt!
Nervous system suppressant my ass! *tottles off to stomach'gasm the fluro yellow*
I'm a pretty constant Rocketing Rabbit (which is the best I can do... sober LOL)
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
