Yeah got access to an engine hoist.
Basically I just need to remove the oil filter housing, install the sandwhich plate and put the food feel line on. The joys of an engine conversion nobody has done before, you learn the hard way. :)
Skillset?
I'm awesome & shit... nah, reception mainly but i've done retail work & worked in the public service as well.
Check the wasteland for skill set... :troll:
Lol that'd be a good resume, just get all my posts into a Word doc.
Any chance SAU can put down some music on their website ? Mayhaps link something via windows media playa to one of the Internet radio stations huh huh huh....
I'd rather listen to my own stuff.
Prue, I'll find out what this posi will be paying and get back to you if you want. Located in Tuggers.
Edited by MIVEC
Prue you should try to find yourself an EA position in a public service org like Centrelink/DHS/Medicare. You'd almost certainly be located here in tuggers, and it's practically a glorified secretary :P that, and you'd be hard-pressed to even find one lower than APS4
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
