lol
mate has a ve ss and wanted to do that. he also owns a vl that his building a 30det for.
i said he could put the chev badge on his ve if he put a nissan badge on his vl. got a blank look.:rolleyes:
ok.
i has 3 more posts till i hit 1000.
so i want a highly intelligent discussion with very well thought-out arguments and counter points to sing in the big 1 0 0 0
!i'll start.
why is poo, poo?
