Any one keen on some home brew stuff cheap??
"So a mate of mine is closing up his home brew shop but has a shitload of stock still to move.
He's based in Queanbeyan and isn't interested in posting anything.
Address is: Sheedy Lane, Queanbeyan, we'll be there after 12 tomorrow for a while and then he'll be around from about 11am each day this week. Enquire at the Tobacconist!
Pretty much everything he's got is near on half price. There is bucketloads of stuff and pretty much every accessory you would want, from drip trays to proper bar taps.
I've snapped photo's to give you an idea. It'd almost be cost effective for Sydney folk to travel if you're going to buy a bit!!
http://farm7.static.flickr.com/6120/...99220452_b.jpg
http://farm7.static.flickr.com/6100/...87eb5198_b.jpg
http://farm7.static.flickr.com/6096/...0775e865_b.jpg
http://farm7.static.flickr.com/6162/...781685a4_b.jpg
http://farm7.static.flickr.com/6222/...1a4e2e87_b.jpg
http://farm7.static.flickr.com/6031/...8fd7c49e_b.jpg
http://farm7.static.flickr.com/6152/...aa8fc62f_b.jpg
http://farm7.static.flickr.com/6212/...6bd55790_b.jpg
http://farm7.static.flickr.com/6161/...4ed4dfa7_b.jpg
http://farm7.static.flickr.com/6092/...51a9dd53_b.jpg
http://farm7.static.flickr.com/6034/...c1f71ee4_b.jpg
http://farm7.static.flickr.com/6100/...4b79770b_b.jpg
http://farm7.static.flickr.com/6056/...a3885e43_b.jpg
http://farm7.static.flickr.com/6059/...2b035199_b.jpg
http://farm7.static.flickr.com/6049/...8e848920_b.jpg
http://farm7.static.flickr.com/6230/...bed46e51_b.jpg
http://farm7.static.flickr.com/6167/...17a00108_b.jpg
http://farm7.static.flickr.com/6045/...0f865b6c_b.jpg
http://farm7.static.flickr.com/6215/...5b080cbf_b.jpg
http://farm7.static.flickr.com/6105/...53595333_b.jpg
http://farm7.static.flickr.com/6179/...613cb8e5_b.jpg
http://farm7.static.flickr.com/6019/...9dfc2dee_b.jpg
http://farm7.static.flickr.com/6046/...4790a633_b.jpg
http://farm7.static.flickr.com/6046/...9f053917_b.jpg
http://farm7.static.flickr.com/6101/...e16710f1_b.jpg
http://farm7.static.flickr.com/6037/...db8c9910_b.jpg
http://farm7.static.flickr.com/6169/...0040303e_b.jpg
http://farm7.static.flickr.com/6172/...56394407_b.jpg
http://farm7.static.flickr.com/6163/...0299b774_b.jpg
http://farm7.static.flickr.com/6112/...a4b9512d_b.jpg
http://farm7.static.flickr.com/6161/...969214c5_b.jpg
http://farm7.static.flickr.com/6232/...a7e59ff7_b.jpg
http://farm7.static.flickr.com/6098/...f5e4a426_b.jpg
http://farm7.static.flickr.com/6032/...2df1923c_b.jpg
http://farm7.static.flickr.com/6100/...80c8a505_b.jpg
http://farm7.static.flickr.com/6172/...c435caa3_b.jpg
http://farm7.static.flickr.com/6153/...23d29638_b.jpg
http://farm7.static.flickr.com/6057/...bb908e03_b.jpg
http://farm7.static.flickr.com/6048/...a2a4d019_b.jpg
http://farm7.static.flickr.com/6053/...f32fb0f2_b.jpg
http://farm7.static.flickr.com/6048/...b8ec6c7f_b.jpg
http://farm7.static.flickr.com/6235/...781686a3_b.jpg
http://farm7.static.flickr.com/6037/...7cb0bbf1_b.jpg"
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
