Talk about bad luck....
On Athlon drive this arve just prior to 4:30.
4 cars in the right lane rear ended each other.
Guy on the very end has no hope - blue commodore with a seriously pushed in front end.
I am out for Temora, cracked block on the dyno this evening FML
Arrgh that sucks :(
The ONLY GTR (not counting 35's) was one of the guys I was sharing a room with! I thought there'd be heaps more Skylines!
I saw that... must have been just after it happened, there were no cops there yet. Went back past later and they had turned up and blocked off the lane.
I hit a roo yesterday too!
I almost hit a bunny on the way to Temora! I hit the brakes and he stopped dead on the line in the middle of the road and luckily decided to turn around and go back the way he came instead of under my wheel..
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
