Who keeps smashing into the signs and cable ducts in the canberra center carpark???
I now look after all those red and green lights that tell you where to park... :)
SO STOP GETTING YOUR TOO TALL CAR IN THERE AND SMASHING EVERYTHING UP!!!!!!!!!!!!!!!!!!!
So I just purchased 13k worth of shares today wish me luck guys :thumbsup:
Also purchased my SS1PU hypergear turbo should be here by Friday next week!
Now for some help with injectors that can handle 250-270rwkw
I was looking to spend around $500 on them or highflow mine.
Just cant decide on whats the better option
fixing your car with offcut metal pipes 2nd hand rads and hunting [email protected] for bargain upgrades but investing.
Hmmmmm - well OK then :thumbsup:
Hahahaha!
The account only just opened up for me to spend yesterday!
I didnt get the turbo from ebay you f**ker
Although I did go cheap compared to MR BIG SPENDER ^^^^^^^^^^^^^^^^^^^^^^^^^^
I hope it want like from a deceased estate - that'd make me cry and feel realy bad.
Did you scratch one of those "win for life" scratchies ???
You should invest in my business :cool: I'll make you ONE MILLLLLION DOLLARS
