hahaha plans enough!
I'm heading down the coast tomorrow morning, bloody hoping the weather does turn to absolute shit....hoping to stay the night down there for a second day on the beach Sunday but if it rains I'll probs just come back Saturday night.
Have shit to do on the car anyway! Fark.
I dare someone to use this upgrade kit:
For $800 it must be top shelf :thumbsup:
Turbo, bov, wastegate, fuel reg, boost controller, turbo timer, ect ect..... the wagers will be on how many minutes till she blows.
Where abouts at the coast Princess? And why do you want the weather to turn to shit :blink:
I have my Xmas party tomorrow night... just bought a purple clutch to match my purple shoes... COORDINATION :D
I assume a few SAUers are going to the Xmas catch up tomorrow?
Narooma, and WHOOPS typo - DON'T want it to turn to shit. lol.
Hey hey!
I've been to the beach pretty much every day for the past two weeks :) you poor canberra folk having to drive so far for the beach!
Good luck with the weather troy, I do hope the water is a bit warmer there than here,
shell you should wear your petty new matching clutch as ear rings so you can show everyone how it matches your shoes!
Good to hear
It's still kinda warm but just rain, rain and rain.
Where was the house?
Was just cloudy before, now she is just rains.
At least you have different walls and oceans smells / sounds.
House was in South Pacific Estate, Martin Avenue. Nearest Beach was Racecourse Beach, only a 5 min walk...
Twas Awesome!!!
Looks like some flamin mongrel in a white car has swiped my van's front-right guard while parking or reversing out next to me at some point in the last couple of days....noticed yesterday arvo some nice damage :( here's hoping that A) it happened in the carpark right outside my gym; and B) the security footage for the entrance to the gym from that carpark can see my car (and prospectively a white car bailing from beside me).
Either that or it has happened while being parked in the driveway at home and it was the neighbours with their absolutely shocking condition Camry. I honestly wouldn't be surprised if it were them, though I doubt I'll see that car in their driveway for a little while nor would I expect to see any orange paint on it when it returns :(
le sigh.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
