You have a few different options.... Go a complete external gate set up using the internal gated turbo ie... get a external gated manifold, tack internal gate shut, buy external gate, make pipe to fit external gate (eventually turbo will crap itself)
Or
Buy high mount manifold, buy slighly bigger turbo 3076 or 3071 with t3 flange, buy external gate, buy 4 bolt dump pipe, install.
For the first option it is a lot of (cutting corner) style work and a lot of mucking around with huge risks.
Or with the second option you can run a slightly safer set up running 10psi or more (if your injectors can handle it) have a bit more boost and its a matter of pull out and replace (less time mucking around)
If you want some quotes on prices for it pm me
Any of you folk with the 32 GTR's keen to drive up to this side of Sydney (Silverwater) with me on the 19th of Jan for another Photo shoot ?
Scantily clad models with bewbs will be there drapped over your GTR :D
See linky http://www.skylinesaustralia.com/forums/topic/414692-r32-gtr-meet-photoshoot-and-cruise-jan-19th-2013/
See linky http://www.skylinesa...-jan-19th-2013/
Will be asking R32_GTR owners tomoz. Would be a great cruise :D
My car is so cool
How cool you may ask !
So cool we take spare cool where ever we go. LMFAO
Your all green with Envy - or is that my coolant spraying all over you... hehehe
Im certain Bren thought the Hulk was having a piss when he was under my GTR
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
