and us import owners are the bad guys... :huh:
There's plenty of fresh Burnouts out the back of my work in Mitchell. Could be related.
Has anyone seen the big burnout / Drift through the roundabout on the Barton? Goes across from the Belco side to the Gungahlin side.
They are getting less and less about the cars though...
that's the point.
how many car movies can you do?
they had a limited run from the start.
branching into action, keeping the cats as a secondary role works.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
