14?! Take him to meets you grump ! Tenteen? Lolol.
ROFL! Get around aye Rob?
He also lives in Melbourne with that ovulating meatbag who brought him to term... :rofl:
I wish I got around many much mores... SLaArts !!! :wub:
  • Like 1
True. The inspection came back immaculate. The inspector has never seen a cleaner one in his career for R34 GTT's for its year etc ('98). there is nothing wrong with it bare tyres and break pads. So it turned out really well.
be careful it might be his mate doing the inspection
Maybe - the inspector was paying him out though haha. He said he is pretty filthy and has clothes everywhere in his car. Also, I picked a Melbourne based inspector as opposed to a Geelong based one (Owner lives in Geelong). Fingers crossed it comes out alright. We've agreed on a price and time of pick up - but no deposit was made (He didn't want one) - not sure because he is a nice bloke or because he is hoping for a better deal before I track down there (1.5 weeks away) - so I can't honestly say "It's mine". We've just agreed on a price and time of pick up - he is currently getting a service done on the car.
I can post up some pictures?
THanks : D!
Question regarding Air Filters - Can a SUS Powercore Type LM E4 Core 150mm fit a R34 GTT? Link: http://www.blitzpowerusa.com/products/suslm/suslm.html
I had a look around but couldn't find anything.
Who are you random? Race for pink slips? See you on the streets noobhead.
You almost had me? You never me, you never had your car. Granny shiftin’, not double clutchin’ like you should. You’re lucky that hundred shot of NOS didn’t blow the welds on your intake. Almost had me? Now me and the mad scientist gotta rip apart the block and replace the piston rings you fried. Ask any racer, any real racer. It don’t matter if you win by an inch or a mile, winning’s winning.
You almost had me? You never me, you never had your car. Granny shiftin, not double clutchin like you should. Youre lucky that hundred shot of NOS didnt blow the welds on your intake. Almost had me? Now me and the mad scientist gotta rip apart the block and replace the piston rings you fried. Ask any racer, any real racer. It dont matter if you win by an inch or a mile, winnings winning.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
