Hope it clears up today. Wanted to go for a drive, maybe north side, and check out Rosie.
Friggin windy & rainy still but a glimpse of blue sky - hopefully blow over
It's sunny over this side - I'm heading over to Rob's (2mins from my place) and working on Rosie (Spark plugs) - Can go for a quick cruise-about afterwards if you're heading to the North shire Richard?
Having a suspicious engine cut out at 5,500 RPM in 3rd.
Edited by RosieR34
how much boost are you running?Im running 14PSI and its still alright for a 1.1gap.Im changing mine soon and not sure if i should stay with bigger gap as it gives a better spark or just go for 0.8gap
I'm running 14 PSI at 5,000 RPM and when it gets to around 6,000 RPM a MASSIVE boost increase happens - Rob can confirm this weirdness. However, the Engine cut out has been fixed after Rob and I changed the Sparkies. I think the gap was 0.8 (Rob can confirm).
Surely 14 PSI is unsafe - I was planning to get a R32 GTR Accularator (Spelling?) which will give me 10 PSI.
pretty sure you mean an r32 gtst wastegate actuator. It's the brass fitting that controls boost through the turbo's internal wastegate.
But unless you can easily find one, it is just as easy to use a standard actuator and a bleed valve to get 10-12psi. If you are running 14psi someone has already been fiddling with your boost control, but it's not really like an instant turbo death sentence
32 GTST Actuator. You talk to me...
I honestly think it is all plumbed in wrong and is bleeding all actuator pressure back into the BOV return pipe, therefore Not opening the Gate.
I thought maybe as 33 turbs seem to Splode over 12 psi maybe 34 OP6 turbs would possibly be the same safe level???
Edit* Are OP6s steel not ceramic?
um - not sure that's good value for money. Check through Cooma Diesel (GCG, Garret reps) the cost ....
I was quoted $900+ per turbs way back when.
New = $1250ea for -7's. Now they are $2300 a pair.
You may wish to join Erics GB on the HKS ss' when you find out the price.
He's doing a pair with full kit for $3k :D
(expect commission if he does Mr Deziner)
Edited by Sinista32
You guys totally lost me. So 14 PSI is too much and should be at 12 PSI.
What's this about rebuilding a turbo? Kinda want to avoid that.
EDIT: So 14 PSI max is okay - but to be safe I should be at 12 PSI?
Edited by RosieR34
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
