there is almost as much advertising in that picture than a scene from F&F
I am brand man. Wheres my nikes :laugh:
No, i cant DIY with the safety gear, so its all bought stuff.
I like things! :woot:
Me too, i cant wait to install. :banana:
Not reclinable.
It will only be in for track days, i dont think its safe to have it and the baby seat in the car together.
The harness is clip on, and the seat base bolts in/out easy.
Im trying to get some safety and car control, also the original seat is old and loose, it wont pass scrutineering.
Can hear outside that the High RPMs are getting traction tonight...
Does a static charge produced by the crap weather, cause the right foot to be attracted to the ground like when your hair sticks to a balloon?
Pretty sure I can hear an RB cruisin' round too... ROSIE???
What the hell is with people in those little two door Lancer thingy's!!!! 3 mornings in a row and 3 different cars all trying to race me and show me how fast they are. Jeez!!!!
looooooool. Lancers are generally owned by younger drivers I've noticed - probs coz they're cheap and relatively decent. Shitty little FWD shitbox though, no idea what gives their drivers the impression they have ANY go in them.
Probably just trying to get you to give it a boot haha, like they have no intentions of actually racing - just hoping that you'll put on a show for 'em :P
I had a Getz try and race me down northbourne.
Stopped at the lights and I heard a raspy tin can rattle and looked beside me and it was a bloke signalling to race.
I laughed and took off at about 0.5kmh
While he sped off and "smoked" me
Pretty happy with myself with that one
Sorry man, I was stalking your house hoping you wouldn't notice me. I guess you found me out - I'll put your pot plants back :(
Haha I get this ALL the time. At least once on the way home from work. Yesterday was a Jeep-being an idiot - flogging it around 130km/h in the 90km/h zone, got stuck behind me and gave me beef; yelling at me, telling me to pull over LOL
Shortly after a red P plater I was behind - I was around 20m behind him but caught up when he wogged over a speed bump and flogged it trying to spin his wheels and race off - did this 3 times (Not sure if he was just having fun or trying to prove something), oh he also sped off like a craycray but then got caught in traffic.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
