Situational I think. If you're in the left hand lane and they're quite clearly an arrogant f**khead (male) or just some stupid mindless drone (woman), then yeah f**k them - slow down to be annoying lol.
If you're in the right hand lane and overtaking at a decent speed above the limit, again f**k them....
  • Like 1
Glad you agree!
Because I have had both situations.
The overtaking one gets me the most annoyed.
Doing 110-115 overtaking and they are right up you arse. These are the ones I don't slam my brakes on but instead I just give them the finger.
The ones in the left lane I either tap my brakes or I slow down to a very slow speed until they overtake
  • Like 1
Are there any people here that have used any panel beaters in Canberra and would recommend them? Tax return has come in and will start getting quotes for the damage this week :)
Unless its a Ferrari etc
I wasnt serious. But i do understand if its a show car.
Lots of 4wds and utes with dirtbikes on brindabella rd today, people going for a look at some snow.
However its doing the typical thing, nice and sunny at the cotter but up at mt Coree where the snow is, its still like a blizzard.
Been there on a bike before and its NASTY up there. The ice flies sideways and finds the gap in your armour.
Kelly body in Mitchell are pretty good and decently priced.
  • Like 1
That's going to bring some unwanted heat to the poor VIC guys, as if they don't already cop enough.
Hate how they made mention it was a Nissan skyline but then the other car who ran away from police in the white commo didn't get a mention of the type of car they were driving.
I'm not overly fussed on the conditions of the snow, as that's down the priority list behind partying and bishes. Though if the conditions are remotely acceptable I'll be hitting the slopes Sunday for sure - haven't been snowboarding for 2 years exactly as of today LOL
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
