Who's planning on going to watch MIK climb a hill Tomorrow? + other people with cars I guess, but MIK !!! :woot:
I think I'll head out for a looky... Between 9 and 10.
I'll be heading out with my dad to have a look. Though we usually head out later in the day 1pm onwards
Too many times
RB is easy
1JZ is hard
You will need a variety of open end spanners, and be prepared to cut a couple with a grinder if needed.....so dont go and buy $50 ea Hazet ones lol
Edit - Mother of God...and activity spurt
Poat was in relation to RB gaskets
Haha im in the same boat as Jezz ;)
Usually goes fair late. Don't quote me on this but I think it goes on past 3pm.
Dad and I are hoping to sign up for a family membership soon. He's just rebuilding his car first :D
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
