Although this is Canadian it has a lot of relevant information
Petition to raise the speed limit - https://www.change.org/petitions/raise-the-limit-and-lower-the-toll
Excellent - How do we make our Government LISTEN !
They won't because............. REVENUE !!!
It's not about safety it's about money
but we all knew that anyways ...
Edited by Sinista32
  • Like 1
I remember seeing an episode of Top Gear from the UK where they looked at the spots the goverment had declared as being dangerous and the locations of speed cameras. Not one camera in was located in any of these dangerous locations.
Yep..it is all about revenue.
I bet if you did a similar thing here in Oz and compared those locations declared as blackspots and speed camera locations I bet the result would be the same as in the UK.
So when I gear change or slow down I sometimes seem to get this "bang" from the exhaust. Healthy? Also, anyone know why this is happening?
Edited by RosieR34
Diff backlash is my guess. Do you notice it (not as much) when you throttle on/off in first or second gear, say when you're navigating a carpark?
If you're out and about in Belco area today, swing past my work again and I can confirm my above suspicion in a matter of seconds :)
I notice when slowing up - mainly in gear changes from 4th to 3rd or even 3rd to 2nd. It's a bit of a "Crackle Pop (Bang)". I imagine a HUGE ass flame is coming out the exhaust but I'm sure this is not the case.
I'm guessing it's more of what Duncan has said - unburnt fuel. Can this damage anything in the exhaust? I do like when it happens, however, I rather it not happen if it is damaging something.
p.s I'm still a noob when it comes to cars :(
Edited by RosieR34
Nah don't stress about it damaging the exhaust...worst case scenario is it f**ks with your cat converter or maybe muffler > excuse to buy a fully sick hectic cannon setup LOL
Offer still stands if you're free today - happy to go for a drive around the block to confirm whether it's just exhaust popping (as your last description suggests) or diff backlash :)
Cheers for the offer Princess - gotta head to my sister's after work. Maybe you'll have to come to a Friday night meet and check it !
If warm this friday might duck out.
Pop=normal for aftermarket exhaust
Bang= awesome!, but exhaust leak, too rich can be timing too
Excess backlash is completely different and you will feel the play, there can be a knock no bang lol wtf! Go on a street that is 60kph in fourth constant accelerator, light stab with throttle a little play/small knock is normal. Massive play and big knock is not good.
Edited by Pattey21
My 33 had a "big knock" from the diff...turns out the two vertical mounts at the front of the diff had completely f**ked bushes, so it was a combination of free play in the diff as well as the entire housing moving LOL
Haha lol :-) id be like, wtf is going on back there...
Well there was enough free play in the diff itself I just concluded that was the cause of the sound....then when I went to get the thing engineered, that was one of the faults I needed to fix up haha.
Straight to Bunnings > grabbed a tube of Sikaflex > loosened the bolts on the diff mount > filled the whole gap/bush space with the shit > left to set until the next afternoon > tightened up and passed by engineer LOL
+11ty - Unburnt fuel
you make this happen by your gear change style and throttle actions :D
you think you race car driver uh_huh
quickshifter - lulz
And is this gear change / throttle action that I do healthy?
It normally happens when I do a slow gear change from 3rd-2nd and light on the throttle (Coming up to a 90 degree turn).
I also have one more question ! (so busy at work today hahaha :D)
Okay well, my long term goals for car ownership was planned to go like this:
Long Term:
1. Buy a skyline (R33 GTST) - Keep this thing until it dies (sold it as it couldn't pass pits)
2. Purchase R34 GTT - Keep this as a daily, a stepping stone until I can purchase a R34 GTR (The Dream).
3. Do no mods to Rosie as I have no intention to keeping it (wasting money) - Get R34 GTR and mod the FUAK out of it.
4. Pending work perm and a personal family deal (Rob knows about this one), however, it looks as if purchasing a R34 GTR might be quite awhile down the track (longer than I anticipated - I knew it was going to be couple years but may turn into several).
SO ! What I was thinking, since a new purchase might be quite a few years away - why not mod a car that is meant to be moded, ROSIE !.
My question is - very briefly (Do not want to waste peoples time)
How much would bigger Turbz + supporting mods roughly cost? I figured around the $5,000 mark
ECU+Tune = $2,000
Turbz = $1,500 - $2,000?
Fuel pump - ?
Other - ?
Now, this is all hersay as I need to have a figure in the ball park to even consider modding Rosie but I have done a bit of reasearch and that's all I have come up with :(
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
