It's called "Manslaughter" and not "Murder" for a reason. This is not the USA so the whole "Self defence" act isn't as lawful here in Australia. You murder someone by accident (Whether it be rage from finding your missus in bed with another man - yep - it's not murder if you kill the guy or if it's a drunken punch on the side of the road out of stupidty).
You kill soemone in any defence act it's classed as manslaughter. It may be out of self defence but you'll have a manslaughter charge - this is the case unless I have been taught falsely which wouldn't suprise me lol
So Manslaughter is a Charge. Just because you kill someone in self defence does not mean you will be charged with manslaughter. If the Police think you have acted unlawfully in the act of defending yourself you may be charged with man slaughter.
Have you ever done any security training and learned about the force continuum etc?
If you have defended yourself using appropriate force you will not be charged. I.e. if someone attacks me with his fist and I hit him once with my fist and he die's I would not be charged.
However if a person attacks me with his fist and I pull out a gun and shoot him I would be. The force did not match the threat.
However there are variances to this. So if a female was being attacked by a man and she shot him (with legal firearm ownership) in self defence she may be ok as she could say she legitimately feared for her like. However it is viewed differently if this was a male to male scenario.
Read the last bit of my sentence.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
