Would if I could, but I definitely wouldn't be buying a stock standard Skyline with the proceeds (Golf R would be on the books lol)...would need to be already modified for ~300rwkw or more, ACT rego, and come with a RWC before I'd consider another heartache :(
I'd never buy an R32 :P
Would have to be a very very very neat 33 GT-R (preferably series 3 and modded) or newer.
I'd consider anything with an RB25DET in it, if it were in great condition and cheap lol.....coz god knows the purchase price is only the beginning in this game
I know your feel bro. But now that mine is done. I couldn't care less on the price it cost. WE MISS YA TROY. Go buy like a standed s1 33 or a R32 Gts-t for like 3k just to have fun with :ph34r:
It felt a bit like that last time lol....running the f**king gauntlet of endless problems
It's never done. You know I'm right ;)
And f**k off don't tempt me lol....I just wouldn't enjoy a standard RB25 though :( would be all for blowing a couple of thousand on something I can thrash and enjoy, but for that price I'd never get something I'd actually enjoy :( and if I did, it's because it was well and truly on its last legs lol
Bike still scares me though, so at least I've got something fun to get around on....just want a ballsy car again though heh
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
