Start saving your pennies people. You have 12months to save up and we'll go in for a group purchase: http://canberratimes.drive.com.au/motor-news/2015-nissan-gtr-hybrid-confirmed-20131108-2x5wh.html
Yeah was reading that... The day he died I was at his lights and wanting to get my window washed (Given it's FILTHY), but the lights turned green- saw him limp off to his bucket and that was it.
whats crackin sarvo canberrans?
1) Got my Sexi Muffler on.
2) Nice Drive in the Country.
3) Watched some mad Vehicles on WOT at SM1000.
4) Return Drive.
5) a mild whorin' session.
and how bout our Favy M&M?
  • Like 1
Girlfriend had the car yesterday.
Screw it, it's stopped, i'm going over now and taking a rain coat.
It's just water....or something like that.
Edited by azathoth
Where's your car located Andy? Not under cover?
I drove past your place yesterday but didn't see it.
Rain seems to be intermittent.
Been meaning to ask you, what's the deal with the R32 GTR 2 doors down from you?
Looks to be pretty tidy. Do you know them? Guess they're not on SAU? yet...
In kaleen in my parents back yard. Old man's stag and mums mg or Forrester are in their garage lol. It's been here since the accident because I only have one car port space lol.
Ground is pretty wet now even if the sun comes out so I have called it a day. Might go home, drink beer and wheel shop.
That gtr is owned by an older guy, its his weekend car. I know it has had exhaust and ecu, not sure what sort and possibly turbos, next time I see him ill ask to have a look.
Maybe I can get him to sign up.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
