Congrats Daniel .... Welcome to the world of white 34's, a privilege offered to but a few ... indeed the selected few, you shall never look back. Btw nice car mate.
Haha thanks
It's pearl white as well so does that have added privilege?
Oh and I have some more good news as well.
I finished all the stages of my application for a promotion. Got through the interviews, tests and psych test as well. Now it's left in the hands of HR to decide.
It does make me a little more optimistic being the only person who applied for the promotion haha
Yeah I always clutch in when starting as it puts less strain on the starter motor plus I always park in gear. (no turbo timer)
but on those rare ocassions when you aren't in the car (eg, focused on the engine bay) it'd be a pain. :/
This man speaks the truth.
Nice wheels too. Looks super clean.
Mine is a series one. Series 2 also had a slightly better trim on the seats and door cards. The series one material get's dirty looking quite quickly. Mine has the Altia? body kit not sure if the series 2 had that as an option.
Rosie S1 / Richard S2 (auto)
S1 front bar + lip is the better for sure.
S2 looks a bit more S15 Silvia.
Hmm so does Richards have a similar front bar to me?
Series 2 (manual) also came with a helical diff which is meant to be way better than the viscous.
I dont clutch in.
unless I have to.
and the extra strain is a clutch disc, and input shaft.
not that much.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
