I reckon 180kw of fwd would be heaps of fun...don't bag it until you try something similar :)
the big questions for fun are power, weight and suspension, not just the wheels that are driven
Me too!
I got mine off a mates dad for $500
It was a 68 deluxe ( 1st with windup windows) with an all cast iron 850 in grey primer.
How about the carbie, you tune it by filling it with a different weight oil!
Hydroelastic suspension, no springs, just gel filled rubber things.
Old British stuff is a bit weird, brilliance mixed with stupid and ancient.
  • Like 1
Actually when the New Pulsar was released, Therese and I went and had a look, half considered trading in the Micra.
They are a Very Nice and Tidy looking car.
I would then be known as "Got a Pulsar" or "The Nissan Freak Formerly Known as Not a Pulsar". :P
  • Like 1
Me too!
I had a clubman panel van with a 998 in it with remote shifter and 1.25'' SU carb.
My old man is such a mini nit he got a hydrolastic machine restored so he could change his own fluids.
It was probably even slower than my alfa 33 but it was just as fun as the skyline is.
Hey rob, you know how i said my foot was sore for unknown reason.... now it feels like its broken.
I know its not, but its a mystery why it hurts.
Suspension tweak worked good, maybe too much camber on the back, they felt warm on the inside, whereas the fronts felt evenly warm.
Straight line stability is less and cornering much better.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
