omg they are considering to raise the speed limit in act :D they say its up to canberrans to decide what is the preferred limit
LOL you doofus.... I just saw the repeat. Was nothing to do with Canberra - the guy said he was coming to Canberra to take on the bureaucrats.
He was saying we should all drive at whatever speed we want and then the speed that *most* people did would become the speed limit for that road. NRMA said he was an idiot because the current limits were there after lots of studies by experts.
That was the basic gist of it anyway.
Rosie no longer has insurance :(
Garage time !
yep, mine ran out of insurance the other day, time to drive like a grandma
Get 3rd Party!
If you guys hit anything, you will be paying for it bigtime. (your car plus the other)
3rd party will at least cover the other car.
Get 3rd Party!
Absolutely agreed ... Insurance companies arent known to be very understanding when it comes to getting money out of people who don't have insurance. Get some 3rd Party Only Insurance ... but get quotes, and I think some provide short term or monthly repayments.
Definitely with these guys on that one.. If I didn't even have insurance, third party at the least, I wouldn't be driving my car..
SkyWagon has Third party just in cases.
for insurance, who are you guys insured with? a lot of people don't list imported cars
Shannons. FTMFW!
You have to be over 25 to be with Shannons. That basically leaves you with Just Car iirc.. I looked into it for a while.. being only 20 when I bought my car
Edited by dontyellpl0x
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
