There was never a "dislike" I believe (as per my suggestion). The "Like This" feature was my idea that I put in the suggestion section and got implemented the next day :P
Pretty sure there was something like that loooong before you ever snapped gears in a liner my boy. ;)
You make a suggestion and it happens straight away and I've been trying to get the daily birthday list back to how it was...
been a couple of years now... still no joy. :(
far que.
well now you have another "like"
haha I noticed you enjoy spamming the like once and awhile. 20 notifictions WHUT DA FUAK? :P
far que.
Hmm maybe so, never was probably a wrong word to use :P
Birthday is a very important feature that must be implemented! Just bump it a few times :P
Those who aren't members (me) won't be able to see the thread in the Members section BUT
our beautiful Shell is having a bubby (SOON) due todays :D but not here yet.....
Members if you could please keep us posted. TATS !!!!!!
Hopefully she runs a 9 second quarter and it's a straight run
Goodluck Shellicious and Tatterstalls :thumbsup:
Aww you guys *blushes*
Thanks for the well wishes :wub:
Due date yesterday and I was out posting SAU memberships, how's that for dedication! No news yet - will try to get back in here as soon as I can when we have some action :laugh:
Can't be till later on tonight though - looks like the Banana car will be going to her new home this arvo :(
Thanks Shell! got mine today. :D
Glad / Sad you've sold the 34, and I sincerely Hope all goes well for You, Tats, the Lump in your Guts and the Future.
Ya can't back out now. Good Luck / Break some water. :laugh:
None at all Anthony.
Last email from JLM was that it would be ready 2 weeks ago, haven't heard anything from them since then.
Last message from Iron chef was Wednesday last week saying they were looking into it.
I have followed up with both of them and have not heard anything back yet.
Well because it's an import and every section of the thing is separate then there is nothing I can physically do.
Shipping costs, taxes, purchase in Japan etc.
I'm not patient man I am honestly extremely pissed about it.
Just have no idea what to do or who to talk to.
JLM assure me that it's because of DOTAR delays (even though they had it bounce back for paperwork issues)
IronChef assures me that there is nothing they can do because it's DOTARS.
DOTARS won't talk to me because I'm not the point of contact with them, JLM are their point of contact.
Probably the worst experience I have had to be honest, ever since it landed in Australia I have been chasing it up every step of the way.
They throw me an ETA every couple of weeks and when it's not met then I have to chase up with them and they throw me another ETA with a sorry.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
