I dont know a lot about it but from what I knows I'm not interested in it.
Too few pumps, big dollars to set up, less millage.
I like the idea of cruises and I feel it will limit that and cost more.
But like I said I Dom know a lot about it, might try find a doco
E85 is for the weekend warriors! Premium is for us daily drivers :P
Even though mine isn't a daily, 98 is for me, also my boss pays for it :)
Full flex tune :)
E85 on the weekend and 98 mid week
I have seen these flex tunes, does it run 100℅ on either, or is it like the old gas tunes where it runs better on one? Does the tank need to be nearly empty to swap between them?
Nothing wrong with using E85 Daily. Unless you are running turbos larger than -5's Judd it isn't worth the upgrade though.
I will never run bigger then -5s even -7s would make me chub up enough. I have a mate with an SS on OEM e85, too little servos, it just seems inconvenient to me....unless its a dyno queen. But that's a whole different gear grinding story lol Edited by gtr judd
Full flex means you can run any mixture and it's the best way to go. Price for the tune works out to be double a normal tune so around $1500 but then all you need is a capable ECU and a fuel sensor.
It will of course run quicker on e85 but when running straight 98 it will run just as good as a normal 98 tune because it has the fuel sensor and adjusts the map to suit
  • Like 1
Is a loverly looking Beast. ;)
I Finally got me a decent Camera today thanks to Ebay.
Gone from a 4mp Sony point n shoot to a 12mp Pentax DSLR. 300mm Zoom is also in the Post.
Yay. :bunny: about time.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
