Rebuilt my PC. Pulled it apart, cleaned everything and put it back together. Also put a new CPU cooler in and Overclocked the FK out of it. Result: what feels like a brand new PC! (It's 4 years old)
When I get back can you help me OC my pc
got myself an i7 3770k
Yeah no worries Dan. It's pretty simple. Did you get a decent cooler for it?
That will have to be the first thing I do when I get back. Right now it's just running a stock cooler.
My GPU is a HD7950 I believe, might even purchase another one depending on how much money I save while over here.
An SSD is probably on the cards as well.
This is currently the best value cooler on the market and is ranked 3rd for air coolers. It is the only one worth buying unless you want to water cool your PC. If you have not got an ssd I do highly suggest one. Is the 7950 a 3gb card? If so that is still overkill. I run bf4 on ulta with my old gtx570.
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18670&cPath=23
Happy belated Bithday Shell!
I never knew why shell reduces the content blend in winter. It s because its so hard to start the car when you're at 85%. So when to the servo bought a gallon of 98 o dilute the E85. It started on the first go this morning with ice all over
I'm sure some of you guys have heard of Nigel Petrie and or seen his drift Hilux. Very well put together doco showing his passion and his commitment to what he loves. Great stuff!
http://vimeo.com/93566294
Wow! Awesome Watch.
If that doesn't inspire anyone to turn a spanner then nothing will.
(got the day off today) :D
Gonna turn me a spanner.
I'm sure many of us would love to achieve that moment where no screw or bolt is to much for the mechanical mind ! What he has is a chronic passion - beautiful thing to see.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
