34T is perfect, nice one.
Im getting some new plates too, same letters black and white plastic, slim front. It was the cheapest option.
But still will look ok.
Yeah I always liked my black and white plates.
Sucks that they were not issued by ACT and were the reason behind my defect :(
Those plates may not be as cheap as you think.
I'm pretty sure if you want standard issue plates that are not in sequence, they will cost around the $450 mark.
eg. I was looking at getting YKS-33R for the 4door and that was the approx quoted price. :/
Replacement of plates Fee
Replacing your plates with a tin Y series plate (from stock available in
Canberra Connect Shopfront)
(registration on vehicle must be current)
$37.80
If not in stock would be the Extra cost I was referring to but I am going to look into it again.
Id think $500 is about what that costs. $2500 for custom. The price goes up quite quickly.
When i was there (belco) it was cheapest to get the same plate re-made ($160). A new number costs more because of the paperwork.
Plastic isnt any more expensive, its when you want custom letters the price gets crazy.
So... polishing pads alll cost about the same $20-$25, some real nice ones are $40.
Thing is you can get a professional one for $22 which lasts for ages, or a bit of mattress foam at Supercheap for $25 which will sht itself very quickly.
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
