I was told if the clear is peeling, like on the mirrors, there is a problem with the paint.
You never know what the problem is, it could even be the primer, so you have to strip it all off.
Thats why i stripped my car to metal, and im glad i did, there was a mix of acrylic, 2 pack, and who knows what else.
From what i can see, its different on the bonnet. Lets hope so, or it will be expensive.
The colour matching should be good as its not metallic, but because its red, it gets attacked by uv the most and will fade quicker than other colours.
So you might get a small missmatch in colour after a couple of years.
Thats why paint problems really suck, because you know it will need a full re-paint sooner or later when it starts looking crappy again.
  • Like 1
Respray the Mirrors and Bonnet BLACK! (no colour matching required)
Get your wheels Powder Coated Black or White.
Would Look Awesome. :thumbsup: and gain 50 - 70kws. :woot:
only 50 you'll need fluffy dice to get 70 out of it ..... :closedeyes:
But love the thinking Rob, very logical solution ... do we go matt black? I'll pick up some cans (coz I'm old enough to get em with no Q's) ... you pick up the sandpaper .... into it! :D
Plasti dip costs around $30 a spray can. Different colours like paint but it's a plasticy rubber stuff that you can just peel off without needing paint stripper / sanding etc... SUPPOSEDLY won't harm the paint underneath. (although I've read of it happening)
https://www.plastidip.net.au/
Thats cheap cf vynil in the photo. Nasty stuff..... Oh your grille... oops
Well i do have a compressor and spray guns, etc. If you went acrylic i have thinners and everything. For plastidip youd need a special spray gun.
Aerosol is hard to avoid splatter.
Vynil is best done in summer when its warm. Very difficult when cold.
Black is a good idea, easy to do, cost hardly anything.
Waiting for wax to dry a bit....... too cold.
Edited by D.I.Y. Mik
Hehe rob <3
Yeah plastidip is weird.. Spray it on and it bubbles and does weird things and then dries smooth.. You just need to make sure the surface is really clean beforehand.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
